So after more then 6 weeks of DJI having my Phantom 3, I finally got an email with the cost... $170 US. They never addressed the reason it took off on me or anything. I only got the bill. So since they only considered it a repair, I have to eat the cost of getting a new almost $200 CAD battery due to the fact the crashed one was destroyed.
The damned thing randomly took off from me and was completely unresponsive to the controls. Surely DJI must take some kind of blame for it? It was locked on to 18 satalites and home point was set to where it took off !!!
Any advice with handling DJI would be appreciated.
From DJI:
Please review the attached invoice with the due amount of (170.00). You are being invoiced for the following:
Bottom cover kit: $8.00
Top cover kit: $5.00
Camera kit: $27.00
2 hrs of repair time at $65 per hour: $130.00
Total: $170.00
Here's background on my accident:
http://www.phantompilots.com/threads/phantom-3-pro-just-crashed-what-do-i-do.46902/
My Phantom 3 Pro just went nuts and killed itself !
I was going to fly it over some very old abandoned saw mill. I did the usual... turn on remote, then turn on Phantom 3 Pro (firmware 1.2.6), then start DJI Pilot (v1.2.0) app. I picked it up after it initialized and did compass calibration and put it on the ground. There are the familiar green "safe to fly" bar at the top with 17 satellites connected (P-GPS)
I started the motors, and after a few seconds, made it lift off the ground just over 1m, A few more seconds, then raised it to about 2-3m. Slowly moved it forward for a few meters... so far so good... then BAM! It just full throttled forward and traveled 87m before smashing into the side of a wall. I initially tried pulling back on the right stick to force it to slow down and go backwards, but nothing worked. It happened so fast (to me). The stricture it flew into was (in elevation) a few meters lower than where I was standing.
I managed to locate it using it's last known location and picked up the drone, some broken blades, and the disconnected battery (fully charged). It's 2 1/2 hours later and the battery is pretty warm.
I put in a new battery and started it up. It sees satelites, the gimble initiates and I can see video. I unscrewed the damaged lens cover and the main camera seems fine). I can start the motors (no props on) and the crashed motor also runs, but it's slightly rubbing against the crushed drone arm. It feels like all I need it a new drone body.
I've had absolutely flawless flights. I've gone 500m up and also tried 4.1k out. Not a single issue until today. What more should I do? Call DJI or something?
View attachment 23730 View attachment 23731 View attachment 23732 View attachment 23733
From DJI:
Camera kit: $27.00
Total: $170.00
