Questions about GPS.
Discussion in 'Phantom 2 Vision + Discussion' started by Jenko1989, Dec 25, 2014.
  1. Jenko1989
    Hi guys firstly merrsy Christmas to everybody!
    I was trying to fly my phantom today and i struggled to get a GPS lock, but when i did i kept losing it. I just want to know, will the return to home function work if the phantom saves the home point at the beginning of the flight (rapid flashing green LED'S) but then loses GPS lock during flight? Will it remember the home point and be able to go to it even f it no longer has GPS? Or do you need a full GPS lock for that to work.
    Also, can having an uncalibrated compass affect the GPS?
    Thanks guys, have a good one!
  2. richiewrt
    No, if it looses GPS lock it won't know where it is and will have no frame of reference on how to get back to the home point. If you are loosing sats enough that you are unable to fly in GPS mode I suspect that something is wrong.
  3. MapMaker53
    Long Island, NY
    RTH will not work below 6 satellites, even if you recorded a home point. Without GPS, the phantom does not know where it is and therefore does not know how to get back to the home point. And since GPS relies on the Earth's lat./long. grid, an uncalibrated compass will certainly result in incorrect heading information.
  4. Jenko1989
    Thanks for the reply. So basically if i record a home point, then lose GPS, I could possibly risk losing my Phantom unless i am very careful and bring it back in ATTI mode?
  5. IrishSights
    Bangor, Northern Ireland, UK
  6. Jenko1989
    Ok thanks.
  7. auen1
    Nome,AK USA
    Side question.
    Why are 6 satellites needed?
    Why not 5 or 4 or even 1?
    Seems like something is better than nothing in a pinch?
    Thanks!
  8. erikgraham
    New York and Philadelphia
    Correct... but it's also likely that the drone will reacquire GPS lock on its own and find its way home.
  9. erikgraham
    My understanding is that it needs 6 for accurate 3D GPS, as in latitude, longitude, AND altitude.
  10. flyNfrank
    Indy, USA
    Where are you located?
    And how high are you you going the you are still not getting 6+ satellites?
  11. MacCool
    midwest USA
    The Phantom 2 uses barometric pressure sensors for altitude, doesn't it?
  12. justin00
    Australia
    Search the forums for the gps fix using aluminium or copper tape.
    Here is a link to one of the threads.. there are heaps of threads discussing it, but nothing lately.I think because DJI fixed the problem in the v3's. Is yours v3 ? If so, you don't need to do the mod.
    viewtopic.php?f=27&t=19402
    At the front of my house in the street I could 6-7 satts, but at the park 5 min down the road where I fly I get 10+... Could just be you don't get any in that area... ?
    So your location could also be a factor, especially if you have a v3.
  13. Jenko1989
    I live in Worcestershire in the UK, and I was only less than 400ft high when I lost GPS. I couldn't t go higher as it told me flight limit reached. I later found Out that there is an airfield nearby (as ive never flown in this location before.)
  14. Jenko1989
    How do I know if I have a V3??? Sorry if that sounds silly but I really don't know.
  15. aartsf
    The most easy way to recognise a v3 is looking at the Rx that came with it. When that Rx had gimbal tilting weal on the top left hand corner its a v3; if not you don't have a v3.
    An other question related to your problem though.... as you were flying in a different area than you usual fly, did yoy callebrate the compas before flying?
  16. justin00
    Australia
    ^^ Yip
    Plus I think on your motors it will say somthing like "dji.com" and "960kv"
    Whereas on previous versions the motors say nothing on them.
  17. Mako79
    Sydney Australia
    +1
    Get a prop out and measure the pitch. If its a 50 pitch, then its v3. if its 43 pitch then its the old.
    Kidding....
    Best way is to look at the motors. 2 of motor tips are black to help identify prop direction. If the the threaded part is painted entirely black then you have the v3. If you see a little black dot, then its the old version
  18. Jenko1989
    No i didn't.... :(
  19. Jenko1989
    Thanks, i have the old version then.
  20. Shuether
    Middle Alberta, Canada
    Another way to ID v3, on th serial number sticker on bottom mine says "V 3.0"
Similar Threads - Questions GPS Forum Date
GPS Questions P4P Phantom 4 Pro Discussion Dec 13, 2016
GPS questions Pro/Adv Discussion Jul 16, 2016
GPS Tracker and Misc. Questions Phantom 1 Help Sep 4, 2015
Couple of GPS - atti questions. Phantom 2 Vision + Discussion Mar 11, 2015
Phantom 2 GPS Questions when in "Phantom" Mode Phantom 2 Discussion Feb 10, 2015
