Question: when your drone goes into Auto...,
Discussion in 'Pro/Adv Discussion' started by Hunter Hughes, Aug 18, 2016.
  1. Hunter Hughes
    When your drone goes into auto return mode, will it generally land safely on ashphalt without tipping over? Also any tips on video taking when doing a rotation
  2. HWCM
    Quadcopter, Aircraft or bird. Not a drone.LOL
    Yes as long as the ground it level and free of debris, it will softly land and shut itself off.
    Video taking while rotating? I am not sure what you mean. maybe turn very slowly. ?
  3. Hunter Hughes
    Yes is there any way to set the turn speed to be slower
  4. HWCM
    Yes, you can adjust the yaw speed.
    but I would not mess with anything unless you know what the settings do. Just be a little lighter on the sticks. With practice you can have the quad turn at the speed you want without any adjustments.
    cfd701 likes this.
  5. RedHotPoker
    Edmonton Alberta
    Sometimes RTH descent can be a little fast, & when the touchdown occurs, it can be a quite firm, even creating a small bounce of the drone. It's better in my feeling, to take over landing where possible, and have complete control. When it returns to land, and starts to descend, always pay close attention to where it will actually touch down, as the exact spot can, and often is, a few feet, or a meter away from the take off-home point, which it recorded while warming up.
    You might need to redirect it, even a tiny bit...
    Turn the drone slower by touching controls softer, less stick input. ;-)
    Softer nudges are best, rather than our aggressive purposeful pushing and tilting the sticks. Turning when the phantom is hovering/sitting still, rather than in a bombing mission, can also present a more pleasant motion, to the viewer... Haha
    I am one who needs this advice myself, and often catch myself doing speed turns, only to regret this error in photography, after, transferring my days flights, & then reviewing my several vids on the computer at home.
    I admire other members videos here most, where flight is generally slow, with smooth transitions, calm movements of the camera gimbal & particularly while both are being smoothly manipulated together. Tilt and turn. Practice? I know, and I do!! ;-)
    That over many other parameters seems to bring more professionalism to a video before editing and presentation, than a lot of other features, that are also important and require the videographers attention. Lengthening your RC sticks can also help some pilots, by giving a slightly more precise input and this may also allow you better control in turns.
    If that makes sense, great. ;-)
    Flying slower by giving less right stick... going forward in a crawl.
    She said "Go Gently Bently".
    RedHotPoker
    #5 RedHotPoker, Aug 18, 2016
  6. Meta4
    Meta4 Moderator
    Staff Member
    You can cancel RTH at any time and resume control.
    You don't have to let RTh do the landing.
    Most pilots can select a landing spot better than blind programming.
    BigAl07 likes this.
Similar Threads - Question drone goes Forum Date
Questions about being a Pro Drone Photographer Photography and Film Aug 10, 2017
Using Drone Deploy with DJI GO 4 question Control (Go, Litchi, etc..) Jul 22, 2017
Airdata (Healthydrones) question Standard/4k Discussion Mar 26, 2017
Binding my P3P Mod controller to my P4 Drone questions Phantom 4 Discussion Mar 19, 2017
Question for the Litchi/HealthyDrones Guru's Control (Go, Litchi, etc..) Mar 7, 2017
