I've been reading the antenna modification forum but the more I read it seems the less I understand. I would appreciate if anybody could clear up a few things for moi...
I understand that there basically 2 ways to increase your range. Something called fpvlr from Tony or the itelite antenna. There are 4 stages to fpvlr depending how much you want to spend and how far you want to extend. The itelite on the other hand doesn't have different stages its a 1 shot deal.
But now it appears that fpvlr also can work in conjunction with itelite? For a bunch of reasons I refuse to modify my bird side and so I decided to go with itelite. But then I started reading about boosters and linear polarized antennas from Tony that appear to work with itelite.
I almost went with stage 2 fpvlr instead of itelite but now I'm thinking I could have both? And if so how far could I extend my range? All I truly truly want is to go a mile in all directions with rock solid video feed. The itelite should do that -more or less but if I get fpvlr 2 as well maybe then it would be guaranteed -or msybe then I could go a mile with my camera resolution set at 30 frames a second instead of 15? That would be worth it...
Thanks guys
Thanks guys
