Question re: Litchi app crash behavior
Discussion in 'Standard/4k Discussion' started by Hickeroar, May 31, 2016.
  1. Hickeroar
    From what I've seen around here, there are quite a few people using the Litchi DJI App to control their drones.
    I recently bought the app, but during setup (indoors, drone on the ground) the app crashed several times. My question is: If the app crashes outdoors while the drone is a long ways away, will the drone treat that as a loss of signal and RTH, or something else?
    I just want to check before I'm out there using it and something bad happens as a result of a crash.
    Thanks!
  2. mdowney58
    Mountain City, TN
    There are many threads regarding a conflict between Go & Litchi
    Everyone here recommends "forcing closed" the app NOT in use.
    Sent from my SM-N910V using Tapatalk
    #2 mdowney58, May 31, 2016
  3. DJI Photographer
    It could see it as return to home but it could also just hover. I have litchi and it is useful. Due to the new update you can return to home if the drone loses signal. If the app crashes it might just hover where it is. When I close litchi and open Dji go the drone just hovers. So the answer will be that it will just hover where it is.
  4. Hickeroar
    Thanks for the replies. I'll make sure the DJI GO app is closed, and as long as the drone hovers or RTH I'm comfortable with occasional issues. I just don't want the thing to decide it's time to take a trip :p Overall the Litchi app seems to close the feature gap to where I'd like it to be, so hopefully it works out well. :)
  5. DJI Photographer
    Hope all works out for you
  6. Ambivalent Squirrel
    I go one step further. If I want to switch app from go<-->litchi, I force close all apps and reboot the (android) phone. Only way to guarantee that one app isn't competing with the other. Had no issues since I started doing it
  7. I M Dronaholic
    Good to know, I've been trying to deal with those two apps on my Android. Ended up getting rid of Go...having both in the android didn't work, only on, either one works on the device at a time even with the other turned off completely. I do, however, use both on the ipad.
  8. mikep2323
    You don't need to reboot every time but you can use a app called shut app from Google play store. It force closes all the apps you don't need. Just click on that and let it close everything and open litchi. No problems with any crashing of app.
  9. mcphipps
    Wheatfield Indiana
    Yep. Thats what I use as well. It WILL close any program you want it to.
Similar Threads - Question Litchi app Forum Date
Litchi App Questions Phantom 4 Pro Discussion May 23, 2017
Litchi app home command question Software Jan 21, 2017
Litchi app questions? Control (Go, Litchi, etc..) Oct 15, 2016
3 Questions... and urgent questions about Litchi App... Standard/4k Discussion Sep 29, 2016
Question for Litchi App users Control (Go, Litchi, etc..) Sep 16, 2016
