Question on E300 kit
Discussion in 'Phantom 2 Discussion' started by FedeVision, Oct 8, 2014.
  1. FedeVision
    San Jose, Costa Rica
    Hi all!, I'm waiting for an E300 kit to arrive soon, and am wondering how to solve the no led indicator on the ESCs condition,
    any tip or accessory led that could be used instead of oem leds? without led lights how can I know if P2 has locked home position achieved?
    Whatever tip or info would be appreciated.
    Thanks!
  2. OI Photography
    Clarksville, TN
    Don't use the E300 ESC's, just connect the E300 motors to the existing Phantom ESC's. The ESC's in that kit are quite a challenge to fit in to the Phantom shell, and the stock ESC's work with those motors just fine.
  3. cellarboy
    What are the advantages of the e300 motor upgrade vs stock motors?
  4. FedeVision
    Bought the kit as back up, cause one of my ESC suddenly started to show a problem sign, at start up the motor starts half second or so,
    later than the others, noticeable by sight and ear, fly and hovers fine as usual, so far.
    My idea is to replace the hole kit when it gets no longer flyable.
    Is there any other trouble beyond the fit challenge?
  5. Fyod
    Central EU
    My kit is finally in.
    I would like to ask those who have done the conversion in regards to the bullet connectors:
    I got the extra female 3.5mm ends. Is it best to snip off the old motors, leaving say 3cm to the board?
    Could you expand on how you soldered the wire into the new female bullets? I see there's no mechanical connection there, so I expect I will need to make a small pool of solder in the cup, then make a very good connection connecting the wire in the cup. Did you use flux during the process?
  6. N017RW
    Palm Beach Co.- FL
    A video is worth a thousand, no, ten thousand words. ;)
    Google or YouTube it.
    There's many tutorials out there. :p
  7. Fyod
    Central EU
    Found some, thanks ;)
    Also, just to make sure, the order (red, yel, blk) is the same on both types of motors? Since the E300 aren't colored.
    And the motor rotation drill pit is also same between both models?
  8. N017RW
    Palm Beach Co.- FL
    I can't address the colors issues but... if the rotation is incorrect, just swap ANY two wires to reverse it. ;)
    That's the beauty of bullet connectors! :)
    (what is meant by 'rotation drill pit'?)
  9. Fyod
    Central EU
    CCW (iirc) have a small pit marker on the very top of the thread to visually distinguish from CW.
    [​IMG]
  10. N017RW
    Palm Beach Co.- FL
    AlI can help you with is how to reverse rotation. I have no experience with these motors.
    If the props are self-tightening type then they can't be put on wrong.
    Then motor rotation can be determined by the props.
    Wish I could help more but I have no experience with your kit but DO wish you much success.
  11. Fyod
    Central EU
    No prob. Just got home and the markers correspond to the old motors.
    Now to solder the bits and test.
  12. Fyod
    Central EU
  13. FedeVision
    Great! Thank you Fyod!
Similar Threads - Question E300 kit Forum Date
E300 Kit Install Question Other DJI Drones Aug 20, 2014
Prop Question 9450 vs E300 General Discussion Feb 26, 2015
Dual battery, and E300 motor and 9.4" prop settings question Phantom 1 Discussion Jan 11, 2015
E300 questions General Discussion Aug 6, 2014
Question on HDR pano workflow Editing (Photo and Video) Saturday at 10:20 PM
