Question I hope somebody can answer?
Arlington, TN
My Phantom 3 Standard went down in a river today (it's toast). Just went & got a new one. You have the standard, advanced, professional, & they had one just called Phantom 3 4k. The only difference between it & the professional is the flying distance (maybe a couple more tiny things) my question is....the app only has the standard, advanced, professional, & phantom 4 in the dropdown menu. Do I use the 3 professional option to fly this one? Thanks for any help.
The P34K is closer to the P3S than the P3P. You'll need to register it in DJI GO -- just like you did when you used your P3S the first time. You should see a P34K option after you connect your Phantom to your mobile device via Wi-Fi.
Ok, I got my new Phantom 3 4k out tonight & begin getting it ready. I charged the remote & battery to the drone. Then I turned them on & trued to connect to the app. It downloaded the firmware & then began installing. It got to 92% & said it failed. The remote shut down after that & won't come back on....so I can't finish the install. Any help?
wkflysaphan4
