Question from a newbie
Discussion in 'Pro/Adv Discussion' started by Dic79, Oct 11, 2016.
  1. Dic79
    California
    Hey guys I'm loving my P3 pro! I have a question on setting though, when I fly over my farm fields I'm hitting a restriction at somewhere around 1650 feet. It won't let me go further. I'm using it to check crop irrigation and need to go further. I'm thinking it's a setting I'm not hitting. I've tried setting the max distance to 2500m but it's not doing anything thanks for the help!!
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Try turning off this setting in DJI GO:
    Dic79 likes this.
  3. Shacky
    If you're not already, you may want to consider Litchi. With it, you can use flighthub online and map out a mission or missions around your property and just send off the drone to run the mission as often as you want.
    Dic79 likes this.
  4. Dic79
    California
    I am not a member but I will be looking at it tonight!! That is for the input!
  5. Dic79
    California
    Going to try it in 10 minutes! I'll post if that made a difference!! Thanks for the help
  6. alokbhargava
    San Francisco, CA
    Turning the max distance off should work.
    Dic79 likes this.
  7. Dic79
    California
    Ok that worked!! Was able to hit 2500ft away without issue! Thanks for the help
Similar Threads - Question newbie Forum Date
Newbie here...Question : Does the GPS/ap automatically disable the drone within FCC proximity guidel Introductions Jan 12, 2018
Newbie question - Firmware version Phantom 4 Pro Help Nov 22, 2017
Newbie Question - UK Drone Laws Rules and Regulations Nov 1, 2017
newbie here got a daft question General Discussion Oct 28, 2017
100% Newbie Question Again Pro/Adv Discussion Sep 9, 2017
