Question for those using LCD for FPV
Discussion in 'General Discussion' started by DaveTown, Apr 10, 2014.
  1. DaveTown
    South Jersey
    I've seen a couple of mounts for attaching your LCD to the transmitter. The one that connects to the attachment point between the control sticks strikes me as the easiest to use, but am I missing something? What do you use and why? Are the carbon fiber brackets just as good? What do you feel operational differences are, if any.
    Thanks in advance.
  2. OI Photography
    Clarksville, TN
    I use one of these now, I prefer it to the CF types I tried: viewtopic.php?f=9&t=6239
    Very very sturdy and secure
  3. DaveTown
    South Jersey
    Thanks O.P. Looks interesting. Can't really tell how its attached to the stand. I see that the antena goes through the hole, but the attachment has me guessing. Is it friction fit?
  4. OI Photography
    Clarksville, TN
    Yeah, it snaps very tightly on the bar, and the lip under the antenna mast helps hold it in place as well. It actually takes a fair bit of force to remove it even if you're trying to.
  5. IrishSights
    Bangor, Northern Ireland, UK
    I'm using a GoPro sticky pad and a GoPro tripod screw. I had most of the bits with my GoPro just needed to buy the tripod bit. I use a large split key ring over the GoPro assembly to attach a neck strap. Cheap, cheerful and functional. See this thread: viewtopic.php?t=9100
    I use slighty less GoPro bits than the one shown In this thread, but more or less the same idea.
    Sent from my Galaxy Note 8
Similar Threads - Question those using Forum Date
question for those using ios devices for video playback Standard/4k Discussion Apr 22, 2017
Question for those of you who hand catch: Phantom 4 Pro Discussion Tuesday at 11:54 AM
Question for those who fly a P3P with HDMI module Pro/Adv Discussion Jan 17, 2017
Question for those that have a DBS and running amps. Standard/4k Discussion Dec 18, 2016
A question for those who already have more than 1 Phantom Pro/Adv Discussion Oct 22, 2016
