- Joined
- Jan 16, 2017
- Messages
- 17
- Reaction score
- 1
- Age
- 86
Will it Hurt my Phantom 3 Battery by leaving it in an unheated garage in sub-freezing temperatures? Garage interior temp drops below freezing.
Freezing a battery will probably not damage it, but I wouldn't do it. The problem is when you bring it back to room temperature. Condensation can form and that can short out the battery. If you do store batteries where they can freeze, store them in a airtight bag and keep them sealed in that bag until they reach room temperature.Thank you Ryan, but I need to know "What Happens if the Battery Freezes".
They don't actually freeze, it doesn't contain a liquid. The Lithium-ion cells are composed of solid polymer electrolytes, usually in the form of a gel. When they get cold, the chemical activity that produces electricity slows down. But nothing actually freezes. The risk of damage is when you bring the temperature back up, allowing condensation to form. That could short a battery, which is typically considered a Bad Thing™. While the risk of that happening is probably pretty low, if you just shove them in a freezer, ice could form on the batteries. I would refer you back to the Bad Thing™ video if that situation should ever occur.Has anyone reading this ever had a battery actually "Freeze" from the cold? Can you tell me if it worked OK after it thawed out?
