PV2+ with Futaba (or other) 2.4ghz radio, anybody?
Discussion in 'Phantom 2 Vision + Discussion' started by samd012, Jul 3, 2014.
  1. samd012
    Has anyone replaced the stock radio in the PV2+ with something like a Futaba which runs on 2.4ghz? If so since the video link is also on that frequency have you had any issues with interference or did you do something to move the video off of 2.4ghz. I have a Futaba 10J which I want to use in the Pv2+ but someone on another thread I had mentioned that there may be issues and I am just looking for some input.
    Much appreciated!!!!
  2. Dirty Bird
    Glen Burnie, MD - USA
    You are likely to have issues due to the video & control sharing the 2.4 Ghz frequency. Were they separated by some distance, you would likely be OK with Spread Spectrum. But with both transmitters/receivers in such close proximity, I would suspect major interference.
  3. Entropy512
    This is what I expected, and why I'm planning on eventually switching to OpenLRS UHF for my control link, however:
    I've had pretty good results (as in, no noticeable negative impact) so far with using a T14SG with the bundled receiver installed in my P2V+
    One thing I did was to set the FPV quality/framerate setting to minimum (320x240 15FPS) to minimize the wifi transmit duty cycle.
  4. shelnutt
    If I move up to a Futaba 8j can I still use my DJI App and see the video?
  5. Michigan_PI
    Detroit, MI
    How about the old 72mhz?
    Anyone?
    I have a TON of that stuff lying around and it gets pretty good range too
Similar Threads - PV2+ Futaba (or Forum Date
FUTABA 14SG for PV2+ Phantom 2 Vision + Discussion Oct 2, 2014
PV2+ 6 mos. old compass replaced, now GPS Phantom 2 Vision + Discussion May 31, 2017
Naza won't recognise my pv2+? Phantom 2 Vision + Help Apr 8, 2017
PV2+ no live feed Phantom 2 Vision + Help Oct 8, 2016
Firmware for PV2+? Phantom 2 Vision + Discussion Sep 28, 2016
