- Joined
- Dec 5, 2016
- Messages
- 995
- Reaction score
- 291
- Age
- 41
You have to turn it on here:
Once you are connected to the craft, go into craft settings > advanced settings > enable RTH Remote Obstacle Avoidance.
So far I have tried some testing using a big tree near me and RTH. If this setting is off (which it is off by default) and I initiate an RTH even with all other VPS/obstacle settings on, the drone will not avoid the tree (I had to manually stop it). If I enable this setting, it avoids the tree during RTH. Has anyone else tested and seen similar behavior?
(By the way you should ALWAYS set RTH height higher than you plan to be flying and higher than any obstacles around you!)
