Props
Do your motors have 4 black prop nuts, or 2 silver and 2 black? There are P2 props you can use either way, you just need to know that so you get the right kind.
Where can you get Phantom 2 props that fit the V1? I ordered a set and 2 fit the other 2, no go...
It depends on which motors came on your P1, that's why I asked above about the color of the OP's prop nuts.
If you have all 4 prop nuts the same color (all 4 silver or all 4 black), then you don't have the self-tightening motors (which it sounds like is the case). If so, you can use these: http://1uas.com/DJI-Propeller-9-White-P ... uts-To-Fix
wkflysaphan4
