props and motors
Discussion in 'General Discussion' started by yappy, May 31, 2013.
  1. yappy
    I read about props that break in flight, that makes me get nervous.
    Are there signs on the props that will shows when you need to change out to new props ?
    If I put on a brand new set of props, will they just break mid flight? Or do they need to be worn and stressed over time first ?
    These things make me worry.
    How about motors? What do I look out for to know when I need a new motor or when it needs maintenance ?
  2. jumanoc
    Don't worry about props broke in mid flight, except if you had crashed as stronger as to break them. (stock props). Be careful instead by nuts and prop loosening. Always check tight adjust pre-flight.
    Motors will change their "sound" picth when require maintenance or replacement. Do a manual speed pre-flight for "feel" how each one turn or if find a "track-track" or sticky turns.
  3. Gizmo3000
    Sherman Oaks, CA
    Yes, always a good idea to check props after a crash (or in the event of a tip-over and the props hit pavement or something)
    Otherwise it's nothing to be too concerned about, while they have occurred, it's very rare and usually caused by operator error (over tightening), or crashes..
  4. yappy
    Ok, so as long as no crashes props should be good then ?
    Are gemfan CF props good ? I got a set from rc-drones.com but have not tried them yet.
Similar Threads - props motors Forum Date
Bent props? Motors? Standard Jan 7, 2017
Advanced Running P3 motors without props Phantom 3 Help Jul 2, 2016
Props and motors... Replace after "X" hours? Pro/Adv Discussion Jul 15, 2015
Possible to tilt motors/props on P1? Phantom 1 Discussion Jun 2, 2015
P1, Tmotors, 9443 props, need to reverse motor rotation Phantom 1 Discussion May 31, 2015
