Propeller maintenance
Discussion in 'General Discussion' started by gazcbm, Jun 3, 2014.
  1. gazcbm
    Hi All,
    Ive posted this in the general section as I suppose it applies to all DJI products.
    As part of my pre/post flight checks I have started to inspect and clean the props. After watching a few videos of props going in mid flight, I thought it was a worthwhile exercise.
    It got me thinking...
    Is anybody else this obsessive?
    Is there a recommended life of the props?
    Does anyone replace them periodically regardless of condition?
  2. xgeek
    London, UK, Declination -1.2
    I check my props after every flight. I check the edges and look for any hairline cracks near the hub (give them a bit of a flex by hand). I am also still on my first set of props after 100+ flights.
  3. gunslinger
    gunslinger Moderator
    Staff Member
    Least Coast...
    I inspect my props thoroughly before and after every flight. I also clean off the bug juice after each flight... :shock: :eek:
    -slinger
  4. The Editor
    Some good and valid points made here.
    Props need love as well :D
    I routinely check my props before every flight. On my Phantom I have had cracks appear on the hub and this could spell disaster in flight.
    Also, the bug juice and dragon fly wings need cleaning off and I also check my props for balance every so often. I KNOW they were perfectly balanced when I installed them but multiple flight, multiple murders of flying buggy things can all have an effect on the leading edge of your rotors.
    If your props appear damaged IN ANY WAY....throw them away. New ones cost a few dollars and is it worth risking your $1k plus investment for the sake of a damaged prop?
    Like pretty much any part of your machine, your props should be checked regularly - after all, they are the only thing between thin air and your multirotor!!!
  5. zsalya
    Would it be safe to put the (detached) propellers through the dishwasher to remove the bug juice?
  6. AndysAdventures
    Orange County, CA
    I wouldn't do that.
    If the "heated dry" feature was turned on by accident, it might melt the props.
    You can just wipe them clean with a damp paper towel.
  7. RipperFox
    NO!!! Think organic polymers (plastic). Organic compounds breakdown with heat, even hot water.
  8. HarryT
    Warrington, UK
    Definitely not - hot water could warp the props. Just give them a wipe from time to time with a damp paper towel - that's all it takes.
Similar Threads - Propeller maintenance Forum Date
Flight and maintenance logs for propellers Rules and Regulations Sep 5, 2016
Standard Propellers hard to install Phantom 3 Help Sunday at 3:20 AM
Stealth Drone Propellers General Discussion Aug 8, 2017
Phantom 4 Pro propellers Phantom 4 Pro Help Jul 25, 2017
No propeller guards, slightly vibrating video? Pro/Adv Discussion Jul 17, 2017
