Prop Guard possible damage
Discussion in 'Phantom 2 Vision + Discussion' started by gfo315, Jan 25, 2015.
  1. gfo315
    Rio de Janeiro, Brazil
    That's what they say in the "Newbies, please read this" thread. My Phantom is one week old, and I would like it to be secured with the Prop Guards. But it wouldn't be a nice idea to buy if it's going to be damaged.
    Has anybody already experienced any problem while using the original Dji's Prop Guards?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I don't use prop guards, but I'm thinking VRS will not be an issue if you descend slowly. A descent of 2-3 MPH should be safe.
  3. gfo315
    Yeah I usually land very slowly, but the Failsafe mode may not do so. But what I'm really afraid of are the screws to eat into the motors.
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The screws will not eat into the motors. The problem is that some people remove the props guards and then put the long screws back in (instead of the original screws).
    That's a good point about the RTH feature. If possible, you should always take control back once you can see your Phantom. Even people who do not use props guards have crashed due to VRS while letting the RTH feature land their Phantom.
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    #5 msinger, Jan 25, 2015
  6. Meta4
    Meta4 Moderator
    Staff Member
    The Phantom won't descend faster than 2 m/sec - in RTH or any other flying.
    Propguards will catch wind like sails, will eat your flight time and make it more likely that you get into a VRS situation (and harder to get out of it)
    Prop guards are generally believed to cause more problems than they prevent.
  7. gfo315
    Alright dude, thanks for the help. I was willing to buy it from eBay or B&H but Amazon is really cheap. Also, found a guy on eBay selling the removable prop guards, which also came along with a rope to protect it even more, what are your thoughts on this one?
    http://pages.ebay.com/link/?nav=item.vi ... 1767543054
  8. gfo315
    Idk, when flying close to a post, a tree, wall or something, the prop guards may be very useful not to protect the props, but to prevent them to stop when hitting these objects. The removable guards would be very nice though.
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You can attach a string between the DJI OEM props guards too.
    If I decided to use props guards, I would definitely go with the DJI OEM prop guards since they screw on. There's no telling what will happen if one of the guards falls off. I'm assuming the Phantom won't plummet to the earth, but it might be hard to control.
  10. aartsf
    I use prop-guards for more than 7 months now; first with a phantom fc 40 and later with a p2v+ v3. Never had any kind of vrs-problems. Saved my props (from stalling or damage) at several occasions. Probably prevented also some human flesh damage.
    In conclussion, highly recommanded!
  11. Fplvert
    Southern Idaho USA
    Those look like okay for prop guards.
    The string should catch trees nicely.
    If you fly any other RC aircraft you will find them unnecessary and a bother to transport.
    MHL
  12. gfo315
    Well, think I'm getting the original Dji's Prop Guards, at least while I take my first flights, I don't need to be very afraid of the objects, like I am atm.
    Thanks a lot guys
  13. Meta4
    Meta4 Moderator
    Staff Member
    Propguards will give you a false sense of security.
    You should be very afraid of objects - particularly when learning.
    Trees are the natural enemy of your Phantom and buildings are a close second.
    Learn to control your Phantom in a clear, open area away from trees or buildings.
    Do not attempt flying near obstacles.
  14. Spudboy
    I'm still a newby so I use them for now. My first flights were in a small area close to trees. It isn't about a false sense of security, it's about misjudging distance. Or a big wind gust when close to the ground. If you know their limitations, guards can save you from yourself.
Similar Threads - Prop Guard possible Forum Date
Is repairing broken prop guards possible? Phantom 1 Help May 25, 2014
Possible Case for PHantom Vision with Prop Guards Phantom 2 Vision Discussion Jan 31, 2014
Advanced Propeller guards Phantom 3 Help Jan 1, 2018
Removing Prop Guards Phantom 4 Pro Help Dec 22, 2017
Prop Guard Protective Plugs? Phantom 4 Help Dec 4, 2017
