Prop Calibration Inquiry
Discussion in 'Pro/Adv Discussion' started by McVenturesRC, Feb 4, 2016.
  1. McVenturesRC
    Lake Lanier Area of North Georgia
    Recently my P3 fell and I've replaced the shell. I've recently flown it and everything seems fine except holding a straight flight path. It seems to be slightly out of tune. I'm thinking a calibration to the props might correct the issue, but I don't know how to do that. If you have experience with prop calibration, could you please advise. Thank you.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You probably need to do an IMU calibration.
    If your props were damaged, you should replace them. If you're interested in learning how to balance props though, then check out the following video:
  3. McVenturesRC
  4. Ken Hanks
    Prop balancing is to eliminate or prevent vibration just like balancing a tire. I would look at compass calibration.
  5. McVenturesRC
    Def not compass calibration unless its internal. So it hovers fine. It flys fine. It responds fine. Just won't hold a perfectly straight line. It's better OB and then def strays off on the IB line. Maybe I'm being to picky but I don't recall this issue "pre-fall & fix".
Similar Threads - Prop Calibration Inquiry Forum Date
Phantom 1 GPS and Compass Calibration + Fitting Propellers Phantom 1 Help Apr 14, 2015
prop guards affecting calibration??? Phantom 2 Vision + Discussion Jul 7, 2014
Standard Propellers hard to install Phantom 3 Help Today at 3:20 AM
More on prop balancing and the P4P whine Phantom 4 Pro Discussion Wednesday at 7:33 PM
