Reduces the vibration from an imbalanced prop. Some props are worse than others and about 20% are pretty good without any work on them. Less stress on the airframe and eliminates any jello you might be getting in the video.This might sound stupid, but what does a prop balancer do/achieve?
This video is OK but there are others a little more accurate. This one is using the Dubro same as I use.Thanks for that! And whats the process of prop balancing? Do you attach the prop to the balancer and then leave it or?
