How important is it to balance your props? I can understand if your running after market stuff, but how about stock dji props?
Or the one in my signature. It's betterThere are tons of threads on this topic Just use the search option of the forum..
I'd say it's important enough to test them. If they are out of balance it will introduce vibration. I will say this.. I have tested all of my DJI props and found that none were bad enough to require adjustment.How important is it to balance your props? I can understand if your running after market stuff, but how about stock dji props?
Not all shafts are the same size. Any of these rods will work.Which size shaft do you need for the P3A?
Any of the rods at the above link will work. If you go with a different brand, just make sure it's advertised as being compatible with the P3 (or P2). Not all rods are the same diameter in the center. The important part is the threads on the end of the rod.So say you get a Dupro, you need their 6mm shaft and that will work on the P3?
Correct.you mentioned you use tape - does this mean instead of sanding down the heavier side, you add weight to the lighter side with tape?
