Problem setting home point
Somerset West, South Africa
Hi there
I always do compass calibration before every flight, then after take-off set the home point 20m up, by flicking the S1 switch up and down 5 or more times. With my last two flights I could not get the home point set( fast flashing green lights.) Previously, I sometimes had to try a couple of times before home point would register. I normally have more than 7 satellites where I fly.
Has the speed you flick the switch got something to do with it?
.........or the availability of enough satellites?
..........or interference from other sources?
Has anybody got an idea why this is happening?
I find I need to toggle almost as fast as possible, I go between CL and HL rather than all the way, which seems to work just as well and is easier to do quickly.
Agree it often needs 2 or 3 attempts.
I would like to see this feature as a 'button' in the app, same as they have done for compass.
Why not just wait on the ground until it's set its home point automatically? No need to toggle any switches then.
I like to set the Home Point when in the air in case of a signal loss and return to home. Then I don't take chances with obstructions coming in the way with the return to home action.
jrl
