Problem after latest updates
Jay
UK
Hi all recently updated my dads p2v when we tried it out it lost all satellite links in flight.We nearly lost it and it was a struggle to bring it back and land as it was also a bit windy.We then reconnected it to the PC and then i noticed it said important you need to relink tx to phantom power cycle and recalibrate.After we did this it was flying ok :D
Anyone else had this happen ?
Hello,
I've had perimeters change after update, for no
Apparent reason? So it seems you should follow these
guidelines after ANY UPDATE!
1) hook Tx to ( RC ASSISTANT ) update FIRMWARE
2) CALIBRATE Tx while still in ( RC ASSISTANT )
3) hook phantom to ( PC ASSISTANT ) update firmware
4) while still hooked up run Tx calibration ( to calibrate Tx to phantom )
5) power cycle phantom ( while still in assistant )
6) double check EVERYTHING, Tx cal, IMU status, parameters, ect!
( make sure all setting have not mysteriously changed
7) compass calibration before first flight!
Should be good!
Take care, fly safe!
shimuafeni fredrik
