Thanks - have you optimised the device in any way and have you experienced any lag?Marshmallow works great on my Nexus 6P. I'm pretty sure the Nexus 7 2013 supports Marshmallow also I would definitely update it
On my Nexus 7 2013, I upgraded OS to Marshmallow then removed EVERYTHING that was not needed. Maps and DJI GO is all that's on. No lagging, runs like a champ.
is it safe to remove everything? I never know which apps may affect the running of the tablet?
As Alfex says is good. If you use the Nexus for nothing but P3 use then uninstall anything which you will not use.Android won't let you delete important system apps that are essential to the tablet so it's safe
I did this and the Nexus would not restart and required a factory reset....As Alfex says is good. If you use the Nexus for nothing but P3 use then uninstall anything which you will not use.
Strange I've done it before without any problemsI did this and the Nexus would not restart and required a factory reset....
Can't connect my reset N7 2013 marshmallow, to my P4. its like the USB port isn't working, in development mode USB debugged. Any help would be helpfulMarshmallow works great on my Nexus 6P. I'm pretty sure the Nexus 7 2013 supports Marshmallow also I would definitely update it
