Poor Flight Range < 200m with Stock TX
Discussion in 'Phantom 2 Discussion' started by MStacey, Apr 15, 2014.
  1. MStacey
    Bristol, UK
    Guys, any ideas on other than new batteries needed in TX which I have tried, why I would get such poor distance range out of the stock TX. Plenty on here seem to be flying way out to 1000m or more.
    P2 Non Vision
    Mini OSD
    Ground Station
    Fatshark 200Mw with googles or diversity monitor.
    If I send the Phantom out using the ground station it merrily flies way past 200m following waypoint route but if I use the normal TX fly out to around 200m and it kicks into Failsafe and heads for home.
    I have tried disconnecting the Air End of the Ground Station to see if that was affecting it but no change
    Tried flying away from me in different directions and with the P2 in different orientation and heights unto about 100m.
    [​IMG]
  2. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Post a picture of how you have installed vTX and ground station including antenna routing.
  3. MStacey
    Bristol, UK
    Not sure if I have got the hang of posting images but here goes
    http://www.k9sleepover.co.uk/photo.jpg
    [​IMG]
    The picture is deliberately upside down showing the belly of the P2
    The antennas from the air unit go 1) to left of picture 2) upwards in picture which is towards the underside of Phantom
    Is there something wrong with my layout that would cause the poor range issue ?
  4. thongbong
    This probably won't help with your distance probably, but will help the life of your Video Tx. You should mount it on the other side, as it's the side that dissipates heat.
  5. ginsonic
    Phantom have a default limit. Go in Phantom Assistant and set own limit.
  6. MStacey
    Bristol, UK
    The Phantom does have default limits which if you look are far greater than 200m. Mine are not at default but are at Height 120m Distance 1000m so that is not the cause of the poor range
  7. MStacey
    Bristol, UK
    Thanks for the tip
  8. ianwood
    Staff Member
    Lost Angeles
    Not sure what could be the issue. Your setup looks OK. Have you had any crashes? Could be the receiver board is damaged or one of the antennas is not fully connected. Hard to tell.
  9. MStacey
    Bristol, UK
    No Crashes ( fingers crossed). Will open the P2 and check the antenna connections.
    I am going to see if I can find somebody local ( Bristol UK) who might be willing to bind their TX to my P2 so I can see if it is my stock TX. If I have to buy a new TX would rather put the money towards a Futaba than another dji one ( Have been following other threads with your profiles with interest.
    Thanks for taking a look.
Similar Threads - Poor Flight Range Forum Date
Advanced Flight range is poor Phantom 3 Help Jun 4, 2015
Professional Weak signal, poor flight distance Phantom 3 Help May 22, 2016
Poor video signal during the flight Pro/Adv Discussion Oct 10, 2015
Shockingly poor flight time Phantom FC40 Discussion Jul 16, 2014
P4 - poor range Phantom 4 Help Sunday at 2:19 PM
