Polarizer filters
Discussion in 'Pro/Adv Discussion' started by Newly, Jan 6, 2016.
  1. Newly
    BC
    Can someone tell me what the best brand of polarizer filters for the Phantom 3A and where is the best place to purchase them.
    Donald likes this.
  2. Apilot101
  3. Newly
    BC
    Thank you. I just did that.
  4. lenmcgilvary
    Calgary Canada
    What about Rainbow Filters.
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You can find a list of all of the commonly used lens filters here. Polar Pro filters are nice, but they are not the only game in town.
  6. Donald
    following
  7. SKI-MTB
    Idaho
    I just bought the 3-pack for P3. Purchased directly from Polar Pro and saved 15% with code sharkpro (or proshark, i forget). They are also including a free filter case for orders from their website. I was impressed with the quality of the "free" case (filters are a bit pricey though).
  8. pilot ss
    Seems like everyone is buying the 3 pack from Polar PRO $69.99. Is this the pack with PL1, ND4 & ND8? Or is there another pack that I should be looking at?
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Polar Pro has a few packs available here. The 6-pack is going to be more useful than the 3-pack you mentioned above.
  10. nparker13
    Do you find you have to adjust the polarizer if you change shots?
  11. 2nd2non
    Orange County, California
    If you desire polarizer, Get the cinema series 3-pack. It includes ND/Pol 8 and 16, ND32. This will give you the greatest range for your shots. Use the discount code mentioned above.
  12. 2nd2non
    This is best to inquire of polar pro. They advertise a polarizer not a circular polarizer which is optimized when turning.
  13. nparker13
    They told me you should align when using. I'm wondering if anyone does or if it really makes a difference
  14. Newly
    BC
    It must make a difference, if you turn the Polarizer filter (CP) in front of a computer screen you can definitely see the different filter effects. I was curious to know why it swivelled, now I know that I just have to figure out how to use it effectively when flying.
    I will try the alignment suggestion.
    I am shooting on a bright day with snow covered fields and clear blue skies.
    Does any one have any suggestions or tips.
  15. Wolfiesden
    Milwaukee, WI, Ft Walton Beach, FL
    It absolutely makes a difference.
    A polarizer filter is used in many different ways. First, it is used to cut reflections from glass surfaces like windows and display counters. While looking through the lens (with the polarizer on obviously), rotate the polarizer and you will find a spot there the reflections mostly disappear and you can see right through the glass.
    Another use is to affect skies and clouds. As you rotate the polarizer, you will see the sky darken and the clouds become more contrasty. Its an artistic thing. Too much of it and it looks wrong. You need to view the image through the lens (ie on your device) and then rotate the polarizer until you see the effect and amount you desire in your images. Then get airborn and snap a few to make sure you got what you want. The affect varies with your angle to the sun.
    What a polarizer does is filter out (mostly) light that is not aligned to the filter's axis. Think of it this way, if you took a piece of paper and scribbled back and forth, up and down, diagnals all over it then you cut a slit in another piece of paper and placed it on top of the one you scribbled on, you would only see the scribbles that were aligned to the slit. As you rotate the slit, other scribbles become visible. Thats a basic description on what the polarizer does. Light is like the scribbles and the polarizer is the slit. As you rotate it, it excludes some like while letting others through.
  16. m0j0
    Another thing to consider is where you live. I'm in the southwest. The sun comes up you absolutely need at a minimum ND8. At noon minimum 16 maybe 32. Just my .02
    If you live where it is really bright ensure your kit goes up to 32.
  17. lookin4pain
    Oregon
    **** this thread... I've had the polar pro 6 pack on my wish list at amazon for some time now, and reading this, I just pulled the trigger. I was more or less holding off in concerns about the weight, or if counter weight would be necessary. I've seen people tape on dimes and junk to offset the balance of the filter. Will have to see how it goes...
  18. Newly
    BC
    Thanks wolf and mojo, I will try fiddling with it.
    Here are my parameters, bright snow, bright sky and darker forested areas and light changes drastically depending on the shooting alignment to the sun.
    It's a jungle to get it right.
  19. Wolfiesden
    Most good photography is. Its not a point and shoot world out there but so many attempt to make their cameras do so.
  20. Newly
    BC
    You are so right on that.
    I couldn't understand the poor results with the polarizer lens but I will try the alignment adjustments......
Similar Threads - Polarizer filters Forum Date
How to Set the PolarPro Polarizer Filters General Discussion Jul 22, 2016
Polar Pro (5) ND filters & polarizer for the Inspire 1 Classifieds Aug 31, 2015
Circular Polarizer lens or Polarizer lense Pro/Adv Discussion Jul 13, 2017
polarizer for phantom 4 pro Phantom 4 Pro Discussion May 24, 2017
Polar Pro's $50 lens 3 pack on sale for $17.99 +sh at Best Buy or eBay. Polarizer, ND4,ND8. Pro/Adv Discussion May 15, 2017
