Advanced Pointing RC in aircraft direction
Discussion in 'Phantom 3 Help' started by TC Malker, Nov 14, 2015.
  1. TC Malker
    I'm trying to fly long distance and having problem seeing the bird. Is there a way for me to know which direction to point the RC toward the bird (for maximum transmission)? I suspect it's the radar thingy on GO app, but not sure how that works.
  2. Meta4
    Meta4 Moderator
    Staff Member
    Yes .. the radar display is the answer.
    It shows you the direction to your Phantom and which way it is facing.
    It's not complicated and shouldn't need much explanation.
    A little observation and it should be clear to you.
  3. TC Malker
    Yeah I'm probably overcomplicating it. It just didn't seem to be pointing in the direction I thought the bird is at. I'll test it again where I can actually see the bird.
Similar Threads - Pointing aircraft direction Forum Date
Batch Waypointing Control (Go, Litchi, etc..) Jul 27, 2017
Gimbal pointing slightly right -- how to fix? Phantom 4 Discussion Jun 10, 2017
P3P gimbal starts pointing left, not a set screw problem... Pro/Adv Discussion Jun 5, 2017
Best quality video settings in P4 Pro? 4K disappointing. Phantom 4 Pro Help May 16, 2017
Where is your camera pointing after you turn on your P4? Phantom 4 Help Dec 31, 2016
