Advanced poi will not start
Discussion in 'Phantom 3 Help' started by Andyinswindon, May 14, 2016.
Tags:
  1. Andyinswindon
    Hi Chaps, newbie to the Dji P3a, but not new to r/c.
    I have put around an hour in on the drone, and so far so good, but am having issues with the poi mode.
    I have deselected beginner mode, enabled multi flight mode, and when hovering, switched to 'f' mode.
    I have selected poi, set altitude, radius, direction and speed, set the rth altitude, and a green bar comes up saying 'starting intelligent flight mode' (or words to that effect), but then the drone just hovers on the spot, no movement at all.
    It's going to be something silly, but....what have I missed?
    Thanks in advance,
    Andy
  2. Andyinswindon
    Ok, solved it myself! I had a distance limit set, and I think the POI was set to go beyond it, so it wouldn't initialise. Since removing the distance limit, all functions correctly.
  3. MasterBlaster
    GA
    When you choose poi you must be directly over the poi. Then you use your stick to pull away to the distance you want to be away from the poi radius. Then after setting the settings you mentioned, hit go. Try that and see if it works. It sounds like you are still right above the POI.
    Good luck!
Similar Threads - poi start Forum Date
At what point do I start to worry? Phantom 4 Pro Discussion Jun 21, 2017
P3P gimbal starts pointing left, not a set screw problem... Pro/Adv Discussion Jun 5, 2017
Map Pilot issue start point Surveying and Mapping Apr 10, 2017
Change Start point in 3D map mission! Surveying and Mapping Apr 3, 2017
Standard Litchi waypoint mission won't start/upload? Phantom 3 Help Feb 1, 2017
