Plywood or plastic helipad??
Discussion in 'General Discussion' started by usaken, Apr 20, 2014.
  1. usaken
    Northern California USA
    Hi, finally getting my wings as I learn to fly my new P2V. I have noticed that landing in grass is a real problem. Bird almost always turns sideways becoming a very expensive mini lawn mower. I tried a piece of foamcore board, but realize that it is too light. The downwash gets underneath it and moves it around while you are trying to land. What are you folks using? Thanks
  2. IrishSights
    Bangor, Northern Ireland, UK
    I nearly always catch land or my observer does. For takeoffs on some surfaces I use a rectangle of the heavier foamex board covered with that non slip rubber stuff that stops it sliding about. It doesn't blow with downwash. I cut it to fit into the laptop sleeve of my back pack that I use for carrying the P2. Don't always use it but if grass is wet or long or seaweed on the shore it comes in handy.
    Sent from Samsung S4 via Tapatalk
  3. Seahorse
    Hampshire, UK
    Hand take off or landing where you might have issues... :idea:
Similar Threads - Plywood plastic helipad Forum Date
Plastic peeling off Phantom 4 Pro Discussion Jun 25, 2017
New plastic bonder epoxy General Discussion Jun 5, 2017
P3P : Can i use 2 CF props and 2 plastic dji props simultaneously Pro/Adv Discussion May 22, 2017
Need help getting plastic covers back on the landing gear Phantom 4 Pro Help May 17, 2017
Plastic arm end pieces Phantom 4 Help Apr 4, 2017
