Please Help Guys - FPV Issue Out of No Where [Video Inside]
So I have an obligation with my P2 in 2 days, and yesterday I just went for a casual flight and noticed I am suddenly having problems with FPV.
The display (both video and telemetry/osd) are off where they are supposed to be on the screen, it has this sort of "scrolling effect," -- it's basically unreadable.
Please see this video:
Sorry about the cartoons and kids in the background and the longness of the video. The important things to see are within the first 20 seconds, although I'd be grateful if you watched it through..
Thanks so much.. In a bind here and beyond frustrated!
Setup is P2 - ImmersionRC Tx - iOSD mini - Flysight Black Pearl
How do I even contact the manufacturer. Can't find them online.
Not knowing where you live I would say the monitor is in either PAL or NTSC. Switch it in the monitors menu.
Not sure what the problem is but i would double check all connections if it was working fine before.
Hope you get it sorted
First of all make sure you have on the channel then switch from NTSC to PAL. I believe the UK video broadcast are use PAL. You will find in the monitors menu. If you're not sure read BP manual
That's exactly what mine looked like. Changed the setting in my go pro. 30 seconds.
wkflysaphan4
