Plastic Anti-drop pins
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by PetePerrim, Jun 1, 2014.
  1. PetePerrim
    Christchurch, New Zealand
    Hi All,
    Does anyone have an idea where you can order spare anti-drop pins for the H3-3D? Ive already gone through the two spares supplied with the gimbal and can kind of see that I'm going to be needing more in the future. I want to experiment with different dampers to eliminate jello. These anti-drop pins appear to be 'one use' only.
  2. Peter Evans
    Lot-et-Garonne, France
    Hi Pete,
    The clue is in the words, 'Anti-drop'. In other words, the pins do nothing other than to keep the gimbal attached in the event of the rubber shock-absorbers parting company with the mount. So you can use anything that does the same job. I know one person who uses thin wire ties (like you get around new cables), but most use small plastic cable ties. The important thing is not to zip them up tight, otherwise it defeats the point of the shock-absorbers. So use two of those, leave a bit of slack in them.... et voila.
  3. OI Photography
    Clarksville, TN
    Pete, I would go with Mr Evans' suggestion, but if you particularly want to use the DJI hardware, this is the part you're looking for: http://1uas.com/Part40-ZH3-3D-Damping-U ... uring-Kits
    I don't know where to find it local to you, but that might help you search ("Part40")
  4. formulaphoto
    Use cable ties (zip ties)...cheaper and easier to remove/replace!
  5. PetePerrim
    Hi Peter,
    Thanks for your response, and also to the others who have replied with their help as well.
    Regards
    Pete Perrim
    New Zealand
  6. csivet
    will be in helipal.com's stock next week. i'm waiting too
  7. Xrover
    Los Angeles, Ca
    I do not use them. Nor did I use them with the H3-2D Gimbal. The only time the Gimbal should fall off is when you have a serious crash or if they are not seated properly. If the Gimbal stay's locked to the Phantom during a heavy crash you will most likely damage it anyway. The Anti Drop Pins vibrate.
    You will probably find 50% of us remove them.
  8. tommen
    Some of you say you remove them, can you show us how yo have mounted your?
    I did a mistake when i monted mine h3-3d, by clamping the pins all the way. And now im looking for a new solution.
    How is the gimbal working when its fasten with zip ties? Will it still be able to work as intend? or will it be more wobbly?
  9. edunwody
    South East, USA
    Zip ties work just fine.
    E
  10. Mako79
    Sydney Australia
    Here is a visual..
    [​IMG]
    This is on my vision plus.
    DO NOT tighten the cable tie, and 2 diagonally across from each other is sufficient.
  11. gppms
    Greece.
Similar Threads - Plastic Anti drop Forum Date
Plastic peeling off Phantom 4 Pro Discussion Jun 25, 2017
New plastic bonder epoxy General Discussion Jun 5, 2017
P3P : Can i use 2 CF props and 2 plastic dji props simultaneously Pro/Adv Discussion May 22, 2017
Need help getting plastic covers back on the landing gear Phantom 4 Pro Help May 17, 2017
Plastic arm end pieces Phantom 4 Help Apr 4, 2017
