Pix4D Software
Discussion in 'Pro/Adv Discussion' started by Kyle86, Apr 29, 2016.
  1. Kyle86
    Hi folks,
    Today I've been trying out the Pix4D app and it seems to be pretty good. The PC software is super expensive though. I was wondering if anyone has tried any similar 3d mapping/surveying apps or software they can recommend. So far I've only tried Pix4D and DroneDeploy. TIA!
  2. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    It is a pleasure to welcome you to the Phantom Pilots forum. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
    I have recently downloaded the app and want to try it when time allows. Did you find it easy to use?
  3. Kyle86
    It was really easy to use! It's pretty simple and took no time at all to get the hang of
  4. Malakai
    Wolves, UK
    Photomodeller and 123D catch are good alternatives. Use Altizure's free app to capture the required photos of an area. It works perfectly for photogrammetry. You can then share your models on sketchfab of you wanted.
    Our Houses by Malakai - 3D model
  5. sbarton
    NJ
    The Pix4D app works really well and easy for taking pics for you. Only issue is the FPV screen does nit work, so you cant see what you are doing. This is a kown issue but they haven't done anything to fix it and its been an issue for a while.
    To get around this i start off in DJI Go app and check altiltude will be safe and then set image settings. Then unplug USB, close GO app, plug USB back in and open Pix4D and let it do its thing.
    Unfotunately this makes the custom flight almost impossible since you cant see what you are doing.
    Scott
  6. Malakai
    Wolves, UK
    yeah thats why i started using the altizure app. it works perfectly.
Similar Threads - Pix4D Software Forum Date
Pix4D software Pro/Adv Discussion Oct 13, 2016
Aerial mapping software advice - pix4D ? Advice please Phantom 2 Vision + Discussion Aug 5, 2016
Phanton 4 pro+ ( mission) with dronedoplay / Pix4D Phantom 4 Pro Discussion Jun 27, 2017
Pix4D and Demolition Site Photos and Video Jun 26, 2017
Pix4dcapture and Near-IR help for P4 Phantom 4 Help Jun 13, 2017
