Pitch Control on Phantom 2 is too sensitive
Any Suggestions?
I used RC Assistant and also Phantom assistant. When I use the pitch lever it is very sensitive. Very hard to get the angle I want using the pitch lever. Any Suggestions?
Only way I know is to upgrade to a futaba or similar. Sorry not much of a help..
Have you thought of replacing the potentiometer in the transmitter?
I gather you are talking about the pitch for the GoPro. The new s/w allows you to set the speed at which the pitch works at. I found it helps quite a bit at getting what you want with smooth pitch changes.
Tom
There is a setting for this in the Assistant software. Seems like it moves the best at somewhere between 2 and 4.
wkflysaphan4
