Photos are TOO bright, cant see much in sunlight... will these filters help?
https://www.amazon.com/gp/product/B01DTKT670/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
The link above is the filters.
PolarPro DJI Phantom 4 Filters-Cinema Series-VIVID Collection (3-Pack)
Those are some examples of being too bright.
It looks like your exposure is set to high. You shouldn't need filters to take photos. They are helpful for shooting video though.
Press the right scroll wheel in to select "EV" at the top, right of DJI GO. Then, scroll the wheel to set EV to 0.
You'll be able to see the areas that are over exposed if you turn on the "Over Exposure Warning" setting in DJI GO.
Additionally, with the bird connected to the transmitter, click on the camera icon shown in msinger's image. You then tap the three lines with circles on them further down the menu. Exposure options will appear near the camera icon. Slide that to an appropriate exposure (shutter speed) time and you will eventually see a proper exposure
ok so i got some better results today
But you can still see some flare , is that something the lense will help?
These do look better! Exposure ( fixed aperture and fixed shutter speed) will never produce equal illumination as you rotate your phantom 360 degrees with the exception of perhaps photographing on a gray day. You can set your exposure to automatic and that may alleviate a good portion of your blowout and bloom.
Remember, there are consequences to everything you do trying to get the perfect exposure. Ex., pointing into the sun will cause your automatic exposure to increase shutter speed and you will lose detail in the shadows ( ground ). The opposite is true when making your emphasis on photographing the ground. There is just a limited amount of dynamic range in digital imaging. Shoot in RAW and you will have greater control of your post processing skills.
I do wish I knew more on how post processing in raw. I guess I will need to watch YouTube and learn...
U.K. London Side pushing the Phantom 4. Peace
Utube will give you all the info you want to know as some one some where has more than likely already done it and posted it, knowledge is power
wkflysaphan4
