I need help i have a new phantom standard all was working well until i was asked to update firmware, it failed and now i cant connect phone to controller
Turned rc and drone on then the app it asked to uodate the firmware it started and got to 26 percent then stopped and gave message failed. Cant get the phone to connect now and the drone is making that alarn noise
The app downloads the firmware to the memory card. So, if you can find the BIN, you might be able to manually install it by copying it to the memory card. It wouldn't hurt to try it anyhow.
Did you see the banner about firmware update on top of DJI Go app when you turned everything back on? Or is the phone still not connected to the RC? Does it still make noise?
The drone is making the noise when you turn it on and the lights green under the drone. Yes the phone will not pick up the wifi to connect to the rc, have tried another phone
