Did you use screws that were too long? If you are talking about prop guards, we have seen many people damage motors using the wrong screws. Just something to check.Hey guys. So I have the phantom 3 and I just put the protection crash blades on it and now the one motor won't start up. It started up perfectly fine before I put them protection blades on.. What can be the problem?
I didDid you use screws that were too long? If you are talking about prop guards, we have seen many people damage motors using the wrong screws. Just something to check.
Perform the connections at the designated solder pads on the mainboard (as per original). Some people elect to try and splice the wires with poor results. The fly leads on the motors are comprised of individually insulated strands (magnet wire). Motors as supplied have the insulation removed at the ends and are pre tinned ready for soldering.Hey " With The Birds" can you elaborate on making sure to "perform terminations at board when replacing motor"
Thanks..
No the app doesn't show any errors at all.Remove the motors and examine the windings- damage, if present, should be obvious. Take it from there. If you replace a motor make sure you perform the terminations of the wiring at the main board.
Are you getting any errors displayed in the GO app when powering on or trying to start the motors?
