Anyone know where you can get the grey foam that fits inside the hard shell case...I got a case that was made for the phantom 2 but the phantom 3 doesnt fit was just gonna get some of that foam and try and cut it and make it fit?
What are the inner dimensions of your hard shell?If his case is like mine (Tradecraft/Seahorse) those will not fit as they will be to small.
Someone must sell them. I have seen a sold block that you cut out yourself but I was hoping for a precut version.
I may even just cut my existing one to fit.
Just buy the proper case. Easy
The problem is no proper case exists. Getting foam, allows you to buy a real backpack, that has pockets, or fits your personalized needs and protect your drone.Just buy the proper case. Easy
This is good enough space to modify your existing foam to make it OK for P3.It is a pleasure to welcome you to the Phantom Pilots forum Billstmaxx. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
The outside of the case is identical in either case. It is only the cutouts that are incorrect on the skids by about .5"
Why bother with an entire new expensive case if you already own one? But if your offering one, sure, I'll take it.
Roughly 22" x 13.5" x 6.5"
really Ive never seen it at our Canadian tire in chunks as big as the hard plastic case, Ill have to have another look I was sure I looked there a while back and all they had was the small chunks of foam for the small tool boxesIn Canada you can buy it at Canadian Tire.
Bob
I've got a related issue with a new Fearless backpack I had to send back. My landing gear is 6 5/8" wide by 5 1/2" long. How wide is the Phantom 2?I am in the same boat... who knew the landing skids were wider?
I'm thinking the Fearless backpack I was shipped was really for a Phantom 2, it measured 6 1/8" wide for the landing gear cavity.
Here is a replacement foam set from Seahourse for $34If his case is like mine (Tradecraft/Seahorse) those will not fit as they will be to small.
Where were you with this info a few hours ago?
Like the way baby is crying and not listening to his cries.Where were you with this info a few hours ago?
I just bought the expensive DJI backpack!
