Phantom2, X8R, Taranis, FrSky Cur. Sensor-40A
Discussion in 'Phantom 2 Help' started by 340cams, Apr 3, 2014.
  1. 340cams
    Hi guys,
    I have the Phantom 2, Taranis x9d with the X8R xmitter and a FrySky Current sensor-40A. I understand the current sensor can read the voltage of the Phantom2 smart battery and send the info to the X8R which can be read on the Taranis Telemetry screen.
    I un-soldered the main batt wires from the main board and installed the current sensor in-line, re-soldering the exiting wires from the sensor into the main board. It is a complete connection and the Phantom operates electrically just fine. I have the data connector going from the sensor to the X8R smart port with the Red LED light on the Sensor blinking slowly indicating the Batt port is connected and the smart port is connect.
    Even though I have the Phantom starting up normally and the sensor appears to be functioning as should be, I don't have any voltage or current data reading on the Telemetry screen of the Taranis...what could I be doing wrong?
    Please help...
    Mike
    Here is the link I used to set it up. It is a pdf file https://www.google.com/url?sa=t&rct=j&q ... 5504,d.cWc
Similar Threads - Phantom2 X8R Taranis Forum Date
Taranis x8r bound but Phantom2 doesn't recognize it. Help! Phantom 2 Discussion May 13, 2015
Phantom2, X8R, Taranis, FrSky Cur. Sensor-40A Phantom 2 Help Apr 3, 2014
Taranis, x8r, Phantom2 w/ H3-2D - x1 tilt not working Phantom 2 Help Jan 18, 2014
Find my phantom2+ How accurate Phantom 2 Vision + Help Jul 9, 2017
Phantom2 vision plus back screen diagnosis FPV (First Person View) Dec 30, 2016
