Phantom Vision WiFi
I have my Vision on order. I do have a few questions regarding the FPV system. I will be using this to do photo inspections and would like to use Fatshark Goggles in addition to the screen. The Phantom will be within view at all times, however I want a good view of what the camera is viewing for myself and another.
WiFi: Will more than one device connect to the network? IE an Phone and Tablet?
Will one of these adapters work to send the video to the fatshark goggles?
Samsung Tab 2
http://www.cellphoneshop.net/avtab.html
Samsung S4- The S4 uses a 3.5 jack as does the FS I think??? Rather than the below adapter could I just run a 3.5 to 3.5? Any conversion box needed?
http://www.wirelessground.com/samsu...ogleproducts&gclid=CI_DkLGZyroCFYg1QgodwUUAsg
Why do they not recommend the use of tablets? Is there a resolution issue?
Please understand I am living within the confines of the Vision and identifying if the following will work or if there are better solutions for the Vision platform. I understand there are better options however this has everything I need in a cost effective package prior to going to a much more robust system. This unit will be used as a training platform after proof of concept. Thank you very much for your support and idea's
I was also wondering if this has the ability to support "Futaba FASST standard" I see the 1.1.1 has the ability to sync to a Futaba but I have not seen anything that shows the Vision having this ability.
cokersean20
