Phantom Vision pitch control problem
Discussion in 'Phantom 2 Vision Discussion' started by Ergoadams, Nov 6, 2015.
  1. Ergoadams
    Here is the setup:
    Phantom 2 Vision with 3D Power Brushless Gimbal controlled through Simple BGC board.
    The set up worked fine for a while. Then I started getting this problem with the camera erratically pitching and becoming unstable.
    When I power the Phantom up, the camera/gimbal is steady with no erratic behavior. When I power it up with no blades on it and move it around by hand, it is absolutely normal. Then when I fly it, it starts the pitching behavior.
    Any help is appreciated.
    I have two videos. The first is powered on, no blades, handheld movement of the Phantom.
    The second video is full power and acceleration. This is where you see the issue.
  2. Ergoadams
    I just realized that one of the videos is the wrong one. The first video is blades on but not powered up. The video that I meant to post (no blades, motors powered up) shows the same thing: a 100 percent functional gimbal.
Similar Threads - Phantom Vision pitch Forum Date
Wanted: Phantom 2 vision+ gimbal pitch sensor board Classifieds Apr 12, 2016
DJI Phantom 2 Vision plus F2 Pitch port for 3th party gimbal Phantom 2 Vision + Discussion Mar 26, 2016
3d power brushless gimbal for phantom 2 vision pitch control Phantom 2 Vision Discussion Sep 16, 2015
Want to buy: broken Phantom 2 Vision + gimbal pitch or roll motor Classifieds Jul 14, 2015
Wanted to buy: Phantom 2 Vision + pitch motor control board Classifieds May 25, 2015
