Phantom Virgin
Discussion in 'Phantom 2 Vision Discussion' started by Musinat, Mar 23, 2014.
  1. Musinat
    Hi there,
    great forum!
    I just got my PV and its great, but I have a few problems, I hope somebody can help me.
    A) I cant connect my Iphone to camera, see picture. Tried to upgrade firmware etc, no luck :shock: ???
    B) Can the camera record without the app? If yes how to control it?
    C) Do I need to download software to my computer (MAc) if yes, why?!
    Thanks a lot guys,
    BR
    Musinat
      File size:
      103.2 KB
      189
  2. Pull_Up
    South Oxfordshire, UK
    Hello, and welcome.
    A. You shouldn't need to do anything to firmware. Is the transmitter, range extender and Vision switched on? Have you checked the slider switch on the back of the camera is all the way over to the right? Have you connected to the wifi network called "Phantom_xxxxxx" where the xxx will be unique to your aircraft? Let us have some more into about what you've done up to this stage and I'm sure we can get you up and running.
    B. Yes, you can. Short press on the white button underneath the camera takes a still, long press starts a video recording.
    C. You would be advised to download the Vision assistant for Mac to your computer because it's the only way of applying new firmware to the aircraft. It also allows you to trouble shoot by seeing the condition of your battery and other aircraft systems, and once you are further down the line allows you to tweak and adjust how the aircraft flies. In a few weeks we are expecting an update to give us autonomous flying via waypoints, and the only way to get this and other updates/fixes is via the Assistant software.
  3. Musinat
    Hi there, thanks for your quick and kind answer.
    In regards to A: Yes, I did all that and also double checked that the camera wire was not loose etc... all should be by the book, except it does not work! Maybe the wifi extender is not working/broke?
    Thanks again for any input, re. B and C it was very helpfull :)
    BR
    Musinat
  4. brushlesheaven
    Reset the wifi extender, next to the power switch there is a little hole
    for reseting. Rebind with the code from your box after the extender restarts if necessery and you
    should be good to go...
  5. Musinat
Similar Threads - Phantom Virgin Forum Date
Phantom 3 virgin here!! Pro/Adv Discussion Aug 2, 2016
Phantom for auto parts Delivery in Northern Virginia? Phantom 2 Vision + Discussion Jul 6, 2014
Phantom 3 Advanced controller upgrade Pro/Adv Discussion 9 minutes ago
Phantom 4 RC not fully charging question Phantom 4 Discussion Today at 4:15 PM
Phantom 3 standard no SSID help Standard/4k Discussion Today at 9:33 AM
