Phantom tips over (Weight?)
Discussion in 'Phantom 1 Help' started by J3lle, May 11, 2016.
  1. J3lle
    Overijssel, Netherlands
    Long story short: My phantom 1 tips over when i try to get it in the air. I have a chinese gimbal and a actioncam installed.
    As long as i use a flat thick rubber mat, and the weather is calm it is all right, but im going to norway soon and im worried i cant take off because different surfaces (in grass, or gravel) This happens too if i land. I already changed the motor idle speed. Anything else i need to change?
    Cheers.
  2. Mark The Droner
    Curious - how do you change the motor idle speed?
  3. J3lle
    Using the NAZA-M Software. Its under one of the tabs, You can lower it and higher it.
  4. Mark The Droner
    Cool. Thank you
  5. discv
    London, UK
    I've never seen that option. Anyway, to solve your problem, give it full throttle to launch it clear of the ground- then back off when above 10 ft.
  6. syotr
    I did a mod to mine to move the battery farther back to balance the camera and gimbal. It also lets me use much larger batteries.
  7. J3lle
    Curious, how did you do that? Can you send me a picture?
  8. syotr
Similar Threads - Phantom tips (Weight Forum Date
Professional Phantom 3 Pro Beginner Need Help and Tips Phantom 3 Help Jul 29, 2017
Phantom 4 Pro "Color, Style, LUTs and general setting" tips? (Help) Phantom 4 Pro Discussion Jul 14, 2017
Phantom-Saving Tips and Lessons Learned Phantom 4 Pro Discussion Mar 22, 2017
Sunrise Phantom 3 Pro Footage - Looking for Tips Pro/Adv Discussion Jan 23, 2017
Phantom 3 Pro Firmware v1.10.90 update Successful tips Shared !!! Pro/Adv Discussion Jan 1, 2017
