Phantom suddenly tilts. Do you see this often?
Discussion in 'Phantom 2 Discussion' started by terrylowe, Jan 17, 2016.
  1. terrylowe
    Hattiesburg, MS USA
    First time to fly in a few weeks. Wind is about 15 miles/hr. Really stable flight until this happens. Is this common for you?
  2. egidio
    Are you sure that it was not only gimball that made that tilt? Is it happening often?
  3. terrylowe
    Hattiesburg, MS USA
    No I am not sure. I was flying FPV when the world tilted and when I looked up at the bird, it was level. This is the first time this has happened.
  4. egidio
    try having a p2 on the table powered on (without propellers) and press down gently on the gopro, untill the gimball releases its motors and than go back after a second. If it is the similar movement that you got it was probably that. Also check the cable contacts of the gimball.
    Anyways, do advanced IMU calibration and compass calibration again, just in case.
  5. jason
    Commerce Twp,MI
    Are you using a ND filter on the GoPro?
  6. terrylowe
    Hattiesburg, MS USA
    No
  7. jason
    Commerce Twp,MI
    Which gimbal and GoPro are you using??
  8. terrylowe
    Hattiesburg, MS USA
    Zenmuse H4-3d with Hero 4
  9. jason
    Commerce Twp,MI
    Has this problem happened more than once or was this the only time??
  10. egidio
    by the shake when it comes back, I would say it was gimbal not the phantom that tilted
    terrylowe likes this.
  11. terrylowe
    Hattiesburg, MS USA
    It was the only time.
  12. terrylowe
    Hattiesburg, MS USA
    I will give that a try. Does pushing down on the gopro "reset" the gimbal motors?
  13. jason
    Commerce Twp,MI
    That could have been caused by a gust of wind at the height of the quad
Similar Threads - Phantom suddenly tilts Forum Date
Phantom 4 suddenly detected as a Phantom 3 Pro by remote / DJI Go? Phantom 4 Discussion Feb 8, 2017
Did my Phantom 4 Pro Suddenly Brick During Flight? Phantom 4 Help Jan 25, 2017
My Phantom 4 crashed suddenly Phantom 4 Discussion Nov 5, 2016
Phantom 4 Crashed suddenly Phantom 4 Discussion Jun 13, 2016
Why does my phantom 3 suddenly start swinging side to side and crashes on the ground, Standard/4k Discussion Mar 5, 2016
