I Was thinking about how to clear my workbench and store my Quads Here is a simple solution to use shelf brackets from Lowes. These are the 3' Double rail wall mounting strips, and also shelf brackets (the ones wit two hooks side by side heavy duty type are 111/2". I super glued 1/2" white weather-strip foam on top of the shelf brackets to keep the phantoms arms cushioned and also provides a non skid type surface. As you can see the brackets are spaced inwards as to give the best support so the arms don't sag or warp in any way. Below the Phantoms I extended two more 3" Shelf mounting strips closer together and used 6" brackets with the foam and they support my controllers. I have room for 3 Birds and 3 Controllers. Maybe I should tell the Wife a good way to fill that empty spot would be for her to buy me a Phantom 3 Pro!
~Duke
~Duke
