Phantom SMART battery WARM after flight | worry?
Discussion in 'Phantom 2 Discussion' started by lightingbryan, May 16, 2014.
  1. Its 70 degrees outside (not hot). I just pulled a brand new battery out at 30%. The battery was putting off heat. Maybe this is slightly normal? But its the first time I really remember thinking, this is kinda warm. Lipos have a bad rap if they get hot. Should I worry? No swelling, no other issues, just kinda warmer then my other batteries. To be fair I did pull the batt faster then normal to switch to another batt.
  2. Monte55
    Raymore Missouri
    All my batteries are warm after a flight. Not hot, but warm. That's normal, I always give them the "cheek" test.
  3. Madwak
    I hope you are talking about "bum cheeks" cos the first time you put a red hot lipo on you're cheek you will know why cattle don't like being branded :lol:
  4. KG4MXV
    To morrow I am going to do a test flight and do some thermal imaging of the motors and the battery as soon as I land it.
  5. Almmohd
    Yup my batteries are normally warm right after a flight. The take some time to cool down too.
  6. ElGuano
    The batteries are so small because they're low-C (probably 10-15C). They'll definitely get a bit warm during discharge, but they shouldn't get anywhere near "hot."
  7. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Mine are warm when they come out too. If you have one that is consistently a little warmer than the others, just keep an eye on it. If it gets hot as in uncomfortable to touch, you should stop using it and send it back.
  8. Pull_Up
    South Oxfordshire, UK
    It's very nice in winter time. A freshly discharged smart battery can be a very useful hand warmer when the temperature is around freezing. As others have said, warm but not burning hot is normal.
Similar Threads - Phantom SMART battery Forum Date
Professional Phantom 3 Battery Smart Boards Phantom 3 Help Feb 21, 2017
Phantom 2 battery hack -smart battery to go to ordinary lipo Phantom 2 Mods May 5, 2016
Phantom smart battery life span Pro/Adv Discussion Sep 28, 2015
Question About Phantom 2 Smart Battery Phantom 2 Help Jun 26, 2015
What's the connector called that plugs into the smart pins on the battery connector in the Phantom 2 Phantom 2 Mods May 24, 2015
