Phantom RC assistant
central iowa
Hello all
I can not get the RC assistant to work with windows 10 . I have downloaded the win driver and the assistant from the DJI website. I have a P2V+ I just purchased updated rc and it beebs 3 times on power up any help out there ?
I share your pain! Same here. My Phantom Assistant works, but not the RC controller. What are we missing?
You need to Disable driver signature enforcement:
“Disable driver signature enforcement”
The drivers are still on the web site. Go to phantom 2 vision + and scroll to the bottom.
First off you need to enable installation of unsigned drivers.
Hold down the SHIFT key while you click Restart.
Once your computer has rebooted you will be able to choose the Troubleshoot option.
Then head into Advanced options.
Then Startup Settings.
“Disable driver signature enforcement”. To choose the setting, You will need to press the F7 key.
Once your computer Starts back up you have to manually install the driver. Plug your dji device into the computer "supply power from a battery" and open device manager.
You should see your device listed under ports as "USB Serial Device (COM##)".
Now right click that device and click properties and under the Drivers Tab Click Update Driver.
Then Click the "Have Disk..." Button.
Then Browse to this directory
C:\Program Files (x86)\DJI Product\DJI driver2.02\source64
And Select The Dji Driver "dji_vcom_driver11.inf" and hit Open then OK
Hit Next and allow windows to install the driver software anyway.
Your Device Should now look like this in device manager and the DJI software should be able to connect.
wkflysaphan4
