Phantom radios - Unique or Different?
Discussion in 'General Discussion' started by Pilot_FML, Nov 14, 2013.
  1. Pilot_FML
    Mentor. Ohio, USA
    Can a Phantom radio used to fly a v1.1.1 Phantom be used to fly a different v1.1.1 Phantom and/or a v1.2.1 Phantom?
    If so, wouldn't multiple Phantom radios interfere with each other if used simultaneously at the same flying field?
  2. phantomman
    Each radio is "bound" to the receiver its working with.
    1.1 and 1.1.1 use Dbus radios.
    1.2 and 1.2.1 use PPM radios.
    I imagine 1.1 and 1.1.1 could be interchangeable, and 1.2 and 1.2.1 could be. Perhaps not between the two different types though.
    All the best
    Simon
  3. chopperflyer
    Leeds West Yorkshire UK
    if the radio was bound to the transmitter and the bonding takes would it not be safe, the radio and transmitter are both using 2.4 g. I am not up to much on R.F of the Phantom radio but I am assuming they both use Spektrum modulation.
  4. phantomman
    I think I'm missing your point here. What do you mean?
  5. Dereyes Films
    Great question! I would like to know the answer too. I'm having issues with my channel 7 for pitch tilt and can not get a answer from 3 different forums!! So I figured maybe its the tx and would not want to spend big money to find out by buying a Fatuba or Spektrum so want to purchase a stock transmitter. Only thing is would it be safe to bind it with my Phantom with out having issue or fly away which are suddenly becoming more common.?
  6. Pilot_FML
    Mentor. Ohio, USA
    I'm slowly learning what the differences are between the Phantom radios but its a slow process. Apart from Phantomman's reply, no one has to date posted a reply. I suspect that either DJI hasn't released enough technical spec's to discern "all" the differences between both radios or that they have decided not to make this information public.
    Maybe we can help each other. Describe exactly what you mean by "I'm having issues with my Channel 7...".
    By the way, I wouldn't assume that a binding issue is at the root of many of the reported fly-aways you might have read about. I suspect that many of these incidents are caused by Phantom owners not correctly following (or mis-understanding) software/firmware upgrading instructions. There are some really good posts on YouTube that support this...
  7. labmansid
    Texas, USA
    I'm curious as well as to what issue you are having with the tilt. I am having one myself, reference my thread here.
    I have been considering trying the DIY pot modification in an effort to just getting it to work. If I do, I might risk voiding any warranty, however.
  8. Dereyes Films
    Are you a meth head?
  9. Dereyes Films
    When I go in Naza assistant my X1 slider move continously from left to right with out touching anything.
  10. Dereyes Films
    Is the blue light blinking on your Tarot Gimbal board?
Similar Threads - Phantom radios Unique Forum Date
which Futaba radios with Phantom 2? Phantom 2 Discussion Jun 15, 2014
Radios Phantom TX - I'll start Phantom 1 Help Feb 25, 2014
Phantom radios General Discussion Aug 11, 2013
Standard Phantom 3 Standard with professional antennas. Phantom 3 Help Yesterday at 11:27 PM
Phantom 3 Pro High Speed Wakeboarding Filming Photos and Video Yesterday at 3:31 PM
