Since you guys were doing bearings, and e clips, check this out!
No more loose ( E-Clips ): ( or short circuits caused by loose clips! )
I bought these:
Here is stock motor ( E-Clip ):
I used a very small flat screwdriver to remove ( E-Clip ):
Here is the motor without ( E-Clip ):
Here is finished motor with new ( Spring-Clip ) installed:
( NO chance of flying off EVER ! )
Here is a better look at my clips:
You will also need a SMALL size spring clip tool! ( I made my own, out of an old set of needle nose pliers, I used my dremmel, to grind down tips to fit, worked perfectly.
Here is a pic of my professionally made tool:
OK, not so professional, but they work perfectly, and saved me nearly $10. {:0)
So far so good, with new clips, they are also a bit lighter than stock! Several flights with new hardware, no issues, I took it apart after 15 flights, still holding strong! NO MORE WORRIES!
Take care, Fly safe!
