If your using the DJI plastic props you should have no issues. The op was using carbon fiber props.Thanks for a lot of valuable info offered in this post. I will be a lot more attentive to tightening of the props from now on!
Previously, I could not understand how the 'self-tightening props could spin off in flight.
I'll give you that, but I'd rather have bird in the sky with plastic that no one can see or cares about, than to have the bird on the ground, writhing in pain, begging to be put out of its misery, with 3 out of 4 good looking props...I agree. Can't blame them though. The black props with yellow stripes at the edge looks infinitely better. Makes the aircraft look more pro and not toy-ish.
So what did you determine was the cause & how can you be sure your conclusion is correct?Fortunately I know what the cause was
I know that's what we believe, but I'm curious how the op has the confidence that it won't happen again. That would be hard to determine for sure since he doesn't know the state of tightness before the flight. Maybe it was tight but came loose during flight. If so it will happen again.
I never said you wouldn't care about. Standard. Hehehewas told once you have a advanced you wont care about a standard
