Phantom can't connect? System error battery critically low
Conneticut
Hey y'all, I have a phantom 2v+ and when I went to fly it it showed all info accurately but no fpv just a loading circle. When I took off it said "battery critically low" even when I had just charged it. Then when landed it would say system error. So I bought a new battery only to find that it now says phantom can't connect. Any ideas on what this issue could be?
Sounds like you may have a few issues going on. First the no FPV loading circle leads me to believe that your wifi module maybe died. The second issue is the battery issue. This may have occurred due to the battery connections inside the bird needing to be cleaned.
Hope this helps you get your bird flying again. Best of luck!
jrl
