There is a you tube video about this it is @ 2.5 lbs.
Why would the P be better? Isn't the propulsion system the same as P4 -P?
I remember last time this was posted, most amusing is why you might need to mark the props with a sharpie prior to butchering the end off with side cutters.1:15 is of interest.
Expect to loose 1.2 to 1.7s flight time per gram of additional weight added (weight alone, additional drag is also a contributing factor).I'd like to see some tests without stressing out the motors/propellers with extra unnecessary weight - I was looking more at adding a skin/sticker, gimbal guard and prop guards....not much weight at all, obviously, but would be great to know the overall effect of certain grams on the total available battery life?
RoOSTA
You might want compensate with higher capacity battery option having +500mAh for + 13gr. only extra battery weight if I remember well. Budget permitting..
BEWARE: dont put sticker containing metal particles!
