  1. REALTOR JIM
    I just upgraded the firmware on my new Phantom 4. I can't get it to connect to the RC. I can move the camera but it still says "Connect your DJI device"? Any suggestions?
    Thanks,
    Jim
    PS Anyone in Minnesota that can walk me through my first flight?
  2. REALTOR JIM
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Double-check that you upgraded it properly. You can find detailed firmware installation instructions here.
    REALTOR JIM likes this.
  4. John Locke
    Yorba Linda, CA
    Always update the craft first. If you update the RC first you'll need to rev back so you can update the craft first. Once that's done, then update the RC.
    Optionally you can use DJIs digital assistant 2 on a PC to update the craft. That app is available from the DJI website, free download.
  5. REALTOR JIM
    I used the DJI digital assistant and it upgraded fine. When I went to fly it said I needed to update RC. Updated and it worked perfect. It was my first flight and I was amazed at how easy it was to fly. Very impressed.
  6. vaughn1976
    In the dji go app you can reconnect the remote..just like if you bought a new rc and had to sink them together
  7. laserdoc85
    Atlanta area
    i updated my RC first. Have not done the P4 yet. Do I need to downgrade the RC first then the P4 upgrade? If so how do I downgrade the RC to the previous version?
  8. Blue Bird
    Dade County, Florida
    Read this thread.
    Controller Downgrade and FW Update
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Downgrade the remote controller firmware like this and follow these instructions to upgrade the firmware.
  10. laserdoc85
    Atlanta area
    Have remote on and bird on it always says disconnected . Turn off and on several times and I get nothing !!!!
  11. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Did you follow my steps above?
  12. laserdoc85
    Atlanta area
    Yes but without the bird on it said no firmware was available to downgrade and it had no version listed
  13. laserdoc85
    Atlanta area
    So I turned the bird on thinking it needed to be on and it just said disconennected
  14. laserdoc85
    Atlanta area
    Do I have to send this back?...
    What is the correct sequence to fire everything up. The bird first and then the remote.. doe the bird have to be on to downgrade the firmware.??
  15. RémyHeli
  16. laserdoc85
    Atlanta area
    This talks about a I pad being used. I have a samsung Tab A.
    should be nothing to delete in the cache as I have not even flown it yet. I went ahead and deinstalled the app on my tablet and reinstalled it. Will try again after I get home this afternoon.
    1. Does the bird need to be on to see the firmware on the RC ????
    Im completely new to phantoms so please bare with me.
    2. If the firmware is completely gone how do I get it back?
  17. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Uninstall DJI GO, reinstall it, and then check if a downgrade is available.
  18. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Remote controller, bird, DJI GO.
  19. laserdoc85
    Atlanta area
    got it back!!!!! Firm wear is 1.58. So I will update the bird first then the RG
  20. msinger
    Approved Vendor
    Harrisburg, PA (US)
    What did you end up doing to fix it?
Similar Threads - Phantom Firmware updated Forum Date
Just updated Phantom 4 Firmware, Battery Update? Phantom 4 Discussion Nov 17, 2016
Phantom Vision 2 Firmware updated-Gimbal not working Firmware Apr 10, 2015
updated to new firmware and phantom Flys different? Firmware May 7, 2014
Loading Firmware Phantom Pro Pro/Adv Discussion Saturday at 1:02 PM
which firmware is best for dji phantom 2 vission plus Phantom 2 Vision + Help Aug 3, 2017
